Recently my 2000 voyager has had a problem.
When I start the car and put into drive it will sometimes act like its in neutral then slowly go into drive. It’s an automatic tran- any ideas? Charlie
Start simple: is the fluid up to the full mark?
Did you check the level according to the stamped instructions on the dipstick?
Check the fluid level with vehicle on a level surface, the engine/trans hot and with the gear selector in “P”. If low, top off using ATF+4 ONLY!!!
Follow up with us on this.
transman
