I have a 95 Aerostar with the side passenger door (the slider) stuck closed. Any info on how to get it open besides going to a dealer or a body shop?
usually this is caused when the upper slide pin becomes loose and jams in the track. Crawl in the van and tighten that pin down where it bolts into the door, see if that works.
