Hello,
I recently replaced the stereo system in a 1997 corolla. After intalling it was apparent that the turn signal sound and lights were not working along with the interior light and stereo itself. I replaced fuse for interior lights and stereo and they are working just fine. I checked and replaced fuse for turn signals but they still dont seem to be working. Any ideas?? Thank you in advance.
There should be an actual “flasher” unit that could be out. It’s usually under the dash or on the fuse block. Check the owners manual for location.
Thanks D. I’ll check it out. Could the problem also be from the 4-way (hazard) light being disconnected presently? (I had to remove the center console cover to install).
