Where do I find a transmission pan for a 1998 Jeep Grand Cherokee Laredo?
On The Very Bottom Of The Transmission
Good one! Reminds me of the airplane mechanic’s repair order with the complaint- “left engine missing”. The mechanic wrote down, “left engine found after brief search”.
To the OP- do a google search on “transmission pans” and find a long list of suppliers. The alternatives are the dealer or a junkyard part. You will need to know which transmission you have in order to specify the replacement pan.
You didn’t say if it was a V-8 or 6 but if a V-8 some Dodge pickups might be the same.
Short of a boneyard you might try this. Cheap enough for new.
http://shop.advanceautoparts.com/ProductList.aspx?parttype=1270&ptset=A&searchfor=Oil+Pan
(Good one! “On the very bottom of the transmission”.)
