Could you give me step by step instructions on how to replace the transmission mount.
Before you un-bolt anything
Independently support the engine/transaxle assembly.
In the shop you see a bar reaching accross fender to fender with chains bolted to the lift points. That way the eng/trans doesn’t go anywhere while loose from it’s moorings and c/v shafts, cables, and tubes can remain assembled.
