I wouldlike to ask if some one may be knows what is this type of leak on my engine? This is the first time i saw this oil.
May be some one can explain to me what should i do to check or verify this type of leak. Thank you.
Due to the location of the leak…two possible causes come to mind. One being a sloppy job at adding oil to the engine and the other being a bad oil cap seal.
Meaning my engine is still in good condition? Can you tell if i need to replace something? Thanks
Pull the PCV valve out of the valve cover, and see if it’s plugged.
It’s that green thing with the hose attached.
If it’s plugged, replace it.
What do you mean by “plugged”?
