For the past couple of days, I’ve been hearing the sound of pouring, sloshing liquid when I make a right hand turn. It comes from down below the dashboard, toward the middle. It seems to happen only when I’ve had the air conditioning on, and only when I make a right turn. Today, some liquid actually trickled out onto my foot. Can you suggest what might be going on and how I can get it taken care of inexpensively?
The condensation drain tube for the air conditioning is probably plugged and water is accumulating in the pan and spilling over. Take the vehicle to a shop and ask if they can check if the drain is plugged. Some will do it for free.
Thank you, Tester. I appreciate your reply. One question: it sounds like a lot of fluid is leaking. It sounds like the contents of a 2 litre bottle are being emptied. Would you still say this is condensation?
That is the noise. It is not a leak just trapped water in the air conditioning. The small vent is plugged up. It takes only a few minutes to clear it out properly.
