my car makes a “squeaking noise” for a second or two as soon as I put my foot on the brake or if I tap on the brake. I had this problem for a while.
Otherwise, it brakes well. Any ideas what the problem might be? Thanks!
In order to give a good answer, we would want to know some more information. Tell us all that you know about the maintenance history of your brakes. It doesn’t cost much to have them inspected so I recommend that you do that.
Actually, it is more like a “high pitched” noise than a “squeaking” sound, I will have it checked out by a mechanic.
