i have a honda civic 2003 dx even thou it has 62000 miles on it , the manuel says change the timing belt 10/or 100000 miles if it a belt but if its a chain dont have to or so i think?
question how do i know if my civic 03 has a timing chain or belt what do i have to ask you guys on here
Take a look here:
http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487
Looks like you do not have a timing belt listed, so you should have a timing chain. It does not require periodic replacement.
ok thank you but i should get the plugs changed at 100000 miles or 10 years
You have a timing belt, my sis in law just had her changed out. I think interval is 100-105k miles.
Most Honda’s have belts and if they break, Ka-Ching, $3500…This is not the time for guesswork’ Read your owners manual and learn…
Or 7 years; OP needs to change the belt based on time elapsed.
