my 2000 lincoln navigator makes horn noise from throttle and stalls at low rpms
This is certainly the IAC (idle air control) valve. If you really want to do a test, confirmation is that it will run fine with just a little pressure on the accel pedal. Even a relatively inexperienced person can fix it in 20 minutes max. The part will probably cost $100 or less.
