The front end is sitting low and the shocks are soft. Is there a good fix for this? What is the best brand of struts.
I am replying to my own post to add make & model----Toyota Previa
If the front end is sagging, you may need new springs. Even gas-charged struts are not going to restore the factory ride height. Springs and struts are readily available, and the two most common replacement struts, Monroe and Gabriel, are better than the factory struts, in my experience.
For Toyota’s, you want KYB struts, but you probably need springs too.
Thanks. Do you know if the springs from a 4 wheel drive would be better?
See if Quick Struts are available; they come with the springs on them and cost about $100 each. Monroe.
