Sun roof
I have a 2007 nissan Altima and the sun roof is not working. It does not go back when you press the button. The vent will go up when you press the vent button on the sunroof but the sunroof itself will not go back. Can you help me with the problem. I have checked fuses and it’s not that. Also it seems that the top of the sunroof on the outside of the car seems to be dropping down slightly on the left side. Could it be off track? Help
If it is off track and binding, the motor may not be strong enough to drive it any further. Is there anything in the track that would stop it?
@Lalab
Have you already tried the procedure on pages 2-44 and 2-45?
