Stuck Key
When turning off my car the key only goes half way. I have to wait a few minutes before I can turn the key all the way off and pull the key out. Is this a ignition problem or bad sensor?
If you jiggle your shifter a bit when this happens, does it make a difference?
If you jiggle your shifter or steering wheel a bit
nope
