My key won’t turn in the ignition. I have turned the wheel, jiggled and tapped the key, and it is in park. The key will not turn. The lights do come on and I have unlocked the car with the keypad. Help
Try to put the shift in neutral and see if that helps. Also try slowly pushing the shift lever when turning the key. The saftey switch setting may have jumped a bit out of place.
The shift will not move out of park position.
