Stereosystem
the 2006 lancer has a different colored wiring system that i have not seen.what are the layout of the wires? i just need to know the power and fuse wire.
Are you saying you are installing a high powered sound system and you need to know what wires of the cars electrical system to tap into for fused power and and switched power? Typically experienced installers know not to tap into the cars system (except for switched power).
You’re not planning to cut the wires, are you?
A test light would help you figure out which is which.
If you are needing some kind of adapter, have you tried Crutchfield?
