I own a 2011 ford Taurus the steering wheel shutters left to right at all speed’s.It also pull’s to the right.It only has 35,611 miles on it.Anyone have similar problem?
No, I don’t have similar problem BUT, I will try to help you solve yours.
The cars pulls right and shudders through the steering… So what curb or giant pothole did you hit? Or did you loan your car to someone and it came back mysteriously with this problem? I’d guess that the left front suspension and maybe the wheel hub or wheel itself is bent. A tire may even be damaged.
You need to get the car to a good independent mechanic, come clean on whatever you hit to the shop, and have both front corners checked for bent components and alignment. I’d bet your problem will be found there. Good Luck!
Make sure all lug nuts are tight. Otherwise, get the car immediately to a mechanic, as Mustangman says. This could result in a crash.
A tire with a belt separation can cause that problem.
Have the tires inspected.
Check the tire balance at the same time. You may have lost a wheel weight or two.
