Shaking Intrepid
I have a 2000 Dodge Intrepid with 92000 miles. Several times a day I get a vibration or shaking coming from the right side front tire. It comes and goes. It only happens between say 30 and 50 miles an hour. It stops whenever you hit the gas or turn the wheel to the right. Seems to start mostly after hitting a bump or rough road. Please help !
Take it to a mechanic to have a look. It’s almost impossible to diagnose something like that over the internet.
I agree with MikeInNH. What you should be looking for though are worn steering and suspension components, such as tie rod ends (which were a weak point on the Chrysler LH cars), ball joints, etc. A bad steering center link can cause the problem you’re having too.
