I just bought a used 2005 Chrysler Sebring 2-door. The driver side door “pops” every time I open it. The sound seems to be coming from what I believe is called the “door check”. Is this something that can be easily fixed at home? (Can you supply a “how to”?) It was suggested that a body shop would be the appropriate place to take for repairs.
@SebringSam
If you can figure out how to remove the door panel, you can do it.
Once you have the door panel off, roll the window back up
Find something to keep the door from swinging forward
Replace the check strap
