2005 Toyota Sequoia, tinted glassed has scratches, anyone know of any product to try to minimize?
If you can feel the scratches as you run a fingernail across it, it is too deep to polish out. Consider replacing the glass. If you cannot feel then across your fingernail, an auto glass shop may be able to polish it out for you.
There used to be a polishing soap product called “Bon Ami”, or something like that. Worked OK if the scratches weren’t too deep.
[b] There used to be a polishing soap product called "Bon Ami", or something like that. Worked OK if the scratches weren't too deep.
[/b]
That was and is Bon Ami in the YELLOW not gold can. The Gold can stuff can damage the glass. Both products are still available, but you may have to do some hunting for it. I keep some of the yellow can stuff around all the time.
