200,000+ miles, the least I could do is give her a new computer to work with. Might even get me from 9 miles to the gallon to 11! Ha
Check the relay ports for ground and power as necessary. Perhaps just a faulty connection? I’ve seen relays get hot and warp the plastic at the connectors. if you have power and ground as you should- PCM is fine, and contact to the relay may be at fault.
Shouldn’t he get a fault code 33 if the WOT is bad?
Keep reading…you can’t blame everything on R134 ![]()
