Can anyone suggest a way to safely remove overspray from 1966 Ford T-Bird hubcaps that are painted and chrome… without hurting the original paint?
Polishing compound and elbow grease.
Whoa, be careful about using compounds, they will scratch the finish. Before doing that, try detailer’s clay. If the overspray is not too heavy, clay should do the trick without fear of introducing scratches on either paintwork or brightwork.
