Remanufactured Fuel Injectors - a good choice?
Are re-manufactured Fuel Injectors - a good choice?
I see some on eBay - the seller has good reviews
In general, do people have good success?
I tried changing the O-rings, from Acura, etc but no luck - it worked for a very short time.
A special ultrasonic injector cleaner machine will have the same result.Go to your dealer for that
There are good injector rebuilders that make a good product. They also “blueprint” the injectors so they all perform equally. That is the best situation for making a smooth powerful engine. That’s how most started. Can’t say if E-bay-ers have a good reputation or not. The internet is your friend.
@COROLLAGUY1
How can ultrasonic injector cleaner eliminate leak?
An ultrasonic cleaner will have nothing to do with any leaks. Reman injectors are fine if they’re sonic cleaned AND reverse flushed.
I would clean and reuse existing injectors
watch next video on how to clean your injectors on a dime: https://www.youtube.com/watch?v=8rk0tKtiVic
I did something similar, but used an air compressor to push cleaner fluid through: after only few sprays my multi-port injectors spray pattern changed from from few ports working to all ports working properly and symmetric spray pattern
you might want to grab some rebuild kit like this: https://www.ebay.com/itm/For-HONDA-Fuel-Injector-Service-Repair-Rebuild-Kit-Orings-Filters-96-02-RKFS12/142139940315?fits=Make%3AAcura|Model%3AIntegra&hash=item2118335ddb:g:xMsAAOSwn25aBV9n&vxp=mtr
you would need to check for the kit for your specific vehicle year
youtube is also full of videos specific for Integra, for example: https://www.youtube.com/watch?v=9x0d7deCMpk
