I have 1989 plymouth colt dl wagon the rear spindle nut needs to be replace but ther is no spindle nut anywhere, Is there any way someone out there that might have an idear where I could find one?
What’s wrong with the old spindle nut?
Not sure why you’d need to replace a spindle nut, but you should have several options. A Dodge dealer might be able to order you one, since the Colt was also sold as a Dodge. I also suspect that this rear suspension was used on other Mitsubishis, so a Mitsu dealer should have access.
http://www.factorychryslerparts.com/showAssembly.aspx?ukey_product=4535506&ukey_assembly=615908&ukey_make=1062&ukey_model=15486&ukey_driveline=0&ukey_trimlevel=0&modelYear=1989
If you are replacing them because thery are supposed to be one time use nuts, don’t worry about that just put some wrench grade thread locker on the spindle threads.
