1997 6 cylinder Chrysler Cirrus 162,000 miles
My car will randomly and unpredictably go into limp mode. I suddenly find myself in second gear while my engine is revving at high speed (3000-5000 RPMs) in order to maintain velocity. The check engine light comes on immediately, but usually switches off after 2-3 days maximum, and typically less than that. If I pull over, and turn off the engine, it re-sets, allowing me to start the car, and continue my journey, shifting normally.
Additional pertinent information:
• it happens more often when the weather is warm
• it has happened while traveling down the highway at 65 mph (scary!)
• at times, the shift into second is so abrupt, it feels as though I have been rear-ended
• once, while in a traffic jam and moving at about 20 mph, I hit a pot hole and the engine started revving at 3000, with no change of gears
• a couple of times, rather than throwing me into second, it has seemed to throw me into neutral, with the familiar high revs, but absolutely no power with increased pressure on the gas pedal
• it is happening with increased frequency i.e. I have had to stop as many as six times during an 16 mile trip.
• Recurring computer codes: P0140, P0141, P0700, P0765, P1494
04/2011 replace right front cam seal
Front engine mount
Replace front valve cover gasket w/tube seals
Front bank spark plugs & wires (3 platinum plugs)
Transmission flush
05/2011 cylinder #5 misfire
Replace rear valve cover gasket & tube seals
3 platinum plugs (leaky power steering pump fouled the plugs)
05/2011 recall work #C45 floor shifter ignition/park interlock
Push rod trans- shifter
09/2012 transmission shift solenoid
10/2012 6 new plugs & wires
Plenum gasket
Distributor cap
EGR valve gasket
There has been other service work done during this time period, but (I think) I have included only that which may relate to the transmission. I am so frustrated, and my mechanic is stumped. He has referred me to either a transmission shop, or a Chrysler dealer. After hearing my account of the problems over the phone, the head mechanic at the dealership suggested that it’s time for me to get a new car.
Any help you can provide will be greatly appreciated. Thank you!
