It started when I was veering left, not during sharp turns. It’s defiantly from the drivers side front wheel. and it varies according to speed… now it does it almost all the time. The brakes don’t pull so it’s probably not the rotors. I’ve had two friends with this same model truck and they’ve both had wheels fall off.
It sounds like a front wheel bearing and it will eventually make a wheel fall off, get both wheel bearings checked.
