I have a 94 Grand Marquis that the pass. front and both rear do not go up, the right rear makes a little noise but the others don’t make a peep, but if they go down a little you just work them up by hand. Is this a easy fix, is ir motors, regulators, off track or ??
I can’t see from here. Someone will have to look at each one to figure out what is bad and then fix it. Some are easier fixes than others. Good Luck.
When my car did that it needed new regulators. If you replace the regulators, replace the motors, too. I paid about $70 each for mine (1998 Regal). Look for them on eBay Motors. To be sure, you meed to check for power at the window motors and inspect the regulators.
