2003 Pontiac Vibe, driver’s side window goes down fine first 6", then only front half keeps going lower. Back half stops, and window glass begins to tilt forward. Goes back up. Motor fine. Any idea what’s wrong? Easy fix? Thanks!
You’ll have to remove the inner door panel to figure out what’s wrong. The glass may have separated from its mount or the window mechanism might be broken. Either way the door panel has to come off.
