Hi I have a 98 Altima the driver side window will go down but unless i pull on it and press the power switch it will not go up any suggestions? thank you
The window motor/regulator is probably worn out. When you roll the window down, the weight of the window and gravity help to roll it down. But when you go to raise the window, you now have the weight of the window working against gravity. That’s why it rolls up with your assistance.
You need a new motor/window regulator.
Or the mechanism in the door needs to be cleaned and lubricated. Find out how to remove the inside door panel, do that, and proceed.
