Odometer Not Working
I have a 1991 Jimmy (the little one) and the odometer and trip are not working. The speedo works fine. I replaced the entire instrument cluster and the problem is not fixed. Made sure the new odometer motor turned freely. Checked all circuits and traced the electrical connections plus cleaned all the contact points. Any ideas would be very helpful!
@PVTodd
“I replaced the entire instrument cluster and the problem is not fixed.”
Did you put in a new/rebuilt cluster?
Did you install a used cluster?
Was there any kind of guarantee?
I would be more worried if the speedo wasn’t working
It was a used cluster. Could not find a new one. It is almost 24 years old.
In that case, it’s quite likely a common problem on that cluster
You might consider looking online . . . there might be some website that shows you how to fix it yourself. Or there might be some company that you can send the cluster to for repair
