1997 Buick LeSabre Custom got hit on passenger side door hard …parking lights dont work nor does the tail lights or dash lights, checked all the fuses under the drivers side fuse box with tester…any ideas?
Check for a damaged wire harness. Also, there are fuses and relays under the hood in a separate fuse block.
wire harness…where is it?
File an amendment to your insurance claim and let the shop that did the repair work fix it.
When you checked the fuses did you check the power to them also. Make sure the fuse for those lights has power and if that is okay then check for power out of the switch. It may be bad.
