The electric door locks and dome light does not work. I check all the fuses, what should I check next?
The dome light probably just needs a bulb. You can check the socket with a multimeter. You can do the same with the switch for the door locks. The first thing to know is whether these things are getting power.
Door locks often fail due to the wires coming from the car to the door a the hinge side. There is a switch there for the dome light also. What year Sentra do you have?
- Would this be the drivers door or both?
