Acura AC compressor clutches have a known issue of AC clutch failure. Acura extended the warranty to 5 years or 100 thousand miles which ever comes first. The common failure of the AC clutch is 70+ thousand miles. For people that drive a lot of miles the clutch will fail within the time period but for those of us that drive fewer miles the failure may occur outside of the 5 years. Acura declined warranty for my clutch failure stating that my vehicle is past the 5 year period although much below the mileage, partly because I had not been using Acura for all maintenance. They moved the dealership which was about 30 minutes away and is now one hour away so I use an independent shop and a Honda dealer. After having many Hondas thought I would upgrade but that has turned out to be a downgrade. My position is: Acura once but never again.
Related topics
| Good or bad a/c clutch? | 4 | 1186 | July 30, 2016 | |
| Acura Transmission | 9 | 2617 | March 20, 2010 | |
| Acura transmission issue at not even 90,000 mi | 6 | 850 | February 15, 2010 | |
| 2010 Acura Clutch Issues | 5 | 1124 | December 7, 2010 | |
| A/c total failure - compressor not working | 2 | 1122 | July 30, 2016 |
