Gotta replace the speaker in the door panel of my 93 Mazda Protege’, any help? Basically need to take off the window handle and don’t know how…without damaging it!
If there is not a screw under some kind of cover on the outside it is probably held with the common wire type clip from behind (fits in a grove on the handle shaft) you can find the special tool on one of those “Help” tool displays at the parts store,these clips were very common on GM and many others,sometimes it is possible to push the panel back (around the handle)and actually see the clip.
Thanks, will check for that part.
Gas Runner, Click This Link. It Might Help You.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280039d6e
