Need help with daytime running lights
DOES ANYONE KNOW HOW TO DISCONNECT THESE ON A 97 GEO TRACKER
Why? It is a safety feature built into the truck. You’ll most likely need a wiring diagram to find the correct circuits, which will most likely use a control box or relay underneath the hood somewhere.
This post seems to answer your question:
I wonder why, too. You never have to look at your DRLs, just other folks.
Why turn off a safety device?
I eliminated my DRL’s on my truck because every couple of months one of the lights would burn out.
Bad design,and pain in the neck.
It may be possible to install a switch on the dash to do this.
In my opinion, all DTRs should have a factory bypass to turn them off when you need to. Yes they are a safety device, but I think you should still have manual control over them.
I do not need them in a car wash, in a garage shining in my or the mechanic’s eye’s or while cruising slowly down a gravel road to see where that wild turkey went.
