Need Automotive Name for Beer
I’ll feel like a real celebrity is an ale has the same name as me @ok4450.
It occurred to me that if the alcohol level is in the upper range Straight-8 might fit.
Smokey Brass Ale
Why stop at a dubbel? Go for a quad with Toodles V12, a Sunbeam engine.
Suds-a-baker
Throw-out beering
Beering wheel
Chrysler’s Last Call
Low Gear Beer
Lots of cool suggestions already. I would consider adding the local name either.
Vintage iron ale
cast iron ale
4 stroke ale
straight weight ale
cast iron slug ale
side valve ale
flat tire ale
bald tire ale
spoke wheel ale
wood frame ale
updraft ale
burnt points ale
cracked manifold ale
Hub light; for those who can’t tell the difference.
Auto-dimmer.
Screaming Belt.
Float Bowler.
Clutchbinder.
Torque Tube.
Road Rage.
Barz Leak.
Droplite.
Subaruzo.
High emissions. You can only rent it.
Head Lite
Wheel Axle Ale
Radiator Leak
Cracked Head
Argyll was the name of a Scottish motor company that made cars from 1899 until 1932 then from 1976 until 1990. So something like Argyll Voiturette(named for their first production car), or even Argyll sweater
I can’t be the only one here who thought to look up Scottish car makers to get their idea…right?
@bscar2 that is even a better idea.
Some of you guys need to get agents. Several comedians could use a change in their writing staff.
Smokey Chokin’ Automobile. Lyric from JerryReed.
