My 2006 Mazda MPV radio has suddenly stopped working and it won’t turn on. Is this a broken fuse problem? If so, where can I find it? Also the “floor panel” (the large plastic piece at the bottom of the car that attaches to the front bumper) has gotten loose and is beyond repair. Is there a way to get this cheaper online?
The fuse for the radio will be in the dash fuse panel with the rest of the fuses. The Owner’s Manual should tell you which one it is if it isn’t already marked in the dash fuse panel cover.
Thanks for your response. I looked at the fuse but it’s intact. I tried switching it with another fuse in the box to no avail. Any other possible problem?
