Maximizing life of turbo V6 in F-150
Yep, what @Mustangman said. Also, make sure you check the oil level periodically, and do it correctly. I have read that the Ford V6 Ecoboost engines drain oil quite slowly after shut down, and overfilling can result if you don’t allow enough time for the oil to drain.
