Pull the L/R wheel, locate the ABS sensor, (it’s down next to interrupter ring on the axle, looks like a lipstick with a couple of wires coming out of it. Make sure everything is intact…Remove the caliper, then the rotor/drum and there it is…Check the part, it’s connector and wiring…
Related topics
| Intermittent dropout on one ABS sensor | 10 | 217 | May 3, 2025 | |
| Traction Control turning off along with idiot light on; also ABS idiot light on. Lincoln Mark 8. '98 | 8 | 4931 | November 15, 2011 | |
| ABS kicks in - dry conditions | 4 | 1016 | April 6, 2009 | |
| 2008 Ranger 4x4 ABS issue | 7 | 564 | December 7, 2018 | |
| 2008 Lincoln MKZ possible ABS problem? | 4 | 5875 | October 21, 2014 |
