My son’s 1997 Dodge Pickup always has a puddle of water in his passenger sid floor board. I assume it is condensation from AC. Can someone tell me how to fix it?
Try cleaning the evaporator drain hose out. It should be located on the lower right side of the vehicle about where the passenger’s feet rest.
You can probably access it easier from underneath rather than pulling carpet back, etc.
Use compressed air to blow it out or a soft wire such as a pipe cleaner.
