I hear a knocking sound for a few seconds from the rear of my 2004 Audi S4 when I turn the key to the on position. It is independent of the engine, this knocking occurs with or without starting the engine. Here is a recording of the sound: youtu.be/dxujW1LQztc
My thoughts are the same as Triedaq’s.
Rather than winding up stranded in an inconvenient place, at an inconvenient time, with an inoperative fuel pump, I would suggest that you have your mechanic check this possibility a.s.a.p.
Having the sound be there on the key turn makes me think fuel pump. There’s usually nothing else mechanical that’s powered at the rear. This car doesn’t have air springs does it?
The car does not have air springs. Thank you to those who mentioned the fuel pump, I also had not thought of that.
Update: I had my regular mechanic listen to the recording and he thought right away that it was the fuel filter. He suspects the sound is from the pressure regulator (or maybe it was just a check valve) inside the filter. I’ll follow up with the results of replacing this filter.
