Scary situation, going down the highway about 70 mph using the cruse control, then suddenly it was as if you let off the gas pedal completely. I turn the cruise control off and press the gas, the car stayed at about 1500 rpm even with the gas pressed all the way. I pulled over, still in drive, it crept as if you let off of the breaks but still would not go above 1500 or accelerate at all. I shifted it into park, reverse, neutral, and back to drive, pressing the gas at each, same thing nothing above 1500 rpm. I turned the car off waited a minute and started again, drove like nothing ever happened.
My three part question is, will this happen again, what is the likely cause of this, and how much should it cost to fix?
Thank you in advance!
