When I enter the vechile from the driver side the interior lights do not come on, also when the driver side door is open the buttons for the windows and lock do not work. The passenger side everything works like it should. Any suggestions?
The trouble is most likely due to broken wires in the wire harness located in the door jam. The wires flex when the door is opened an closed and eventually break. The short cable is designed to be replaced and has connectors on each end.
