In search of a 1999 Jeep Cherokee window regulator
I have a 1999 2 Door Jeep Cherokke Sport, emphasis on the 2 door. The driver’s side window regulator is broken and thus the window doesn’t work. Where can I find a part or is there another vehicle that is similar?
Thanks,
Colleen
There is information at Steigerperformance.com about your situation. The two regulator is a discontinued part. Depending on what part broke the above site might be helpful.
Good Luck.
have you tried junkyard.i also own a 1999 jeep cherokee around here where i live one junkyard have about 15 cherokee a graveyard supermarket for me.
Rockauto shows regulators for the 2-door, for both the non-power and power window versions. Did you check there?
My 2007 Town and Country is on its first winter with new window regulators from rock auto. Now even in subzero F temps the windows go down and back up.
Thanks. I will check it out.
I believe my mechanic has checked this. I live in WI. What junkyard do you use? Maybe I can contact them. Thanks.
