I want to change my hub assembly myself but I can’t seem to find the torque spec… I need them for the 3 bolts that holds the assembly and the axle nut.
THe Data that I found is 90 in lbs on the hub bolts.
The axle nut I couldn’t find, but should be 130 in lbs.
Yosemite
The axle nut torque should be 118 FOOT/lbs, not inch/lbs as Yosemite stated. I’m sure that was a typo…haha.
Have you removed the old hub bearing?
Ooooops, I looked at the wrong listing @icecajun. 96 in lbs on the hub nuts
Here is the spec’s page link.
Yosemite
Yosemite, your link says 96 pound-feet, ie, foot-pounds
My mistake it is foot lbs…not inch lbs. I can’t figure out why I typed in lbs…old age…tired brain cells.
Take one viagra and all inches turn into feet.
I took one last night and it got caught in my throat. I’ve had a stiff neck all day!!!
Thanks fro catching that @BillRussell.
no problem. Good story about the stiff neck.
