Anybody know what size socket I need to remove the driveaxle hub bolts from this car? I can see the bolts are considerably larger than the socket I have for my Ford Tauruses, and I would like to eliminate the guess work before I go to carquest to get the proper socket. Unfortunately bringing the car to the store and trying sockets until I get one that fits is not an option, since the car is not running right now.
 Thanks,
 Pop
If you are referring to the axle nut you might ask the man at the parts counter to look up the replacement nut and note the size.
great idea. will try that. thanks.
it worked. its a 36mm bolt. thanks again.
