how to test a abs module or abs pump or where can I find a wiring diagram of the connection
It requires special diagnostic equipment to test the ABS system on your Honda.
Many consumer-grade code readers can now read ABS codes, but that is, of course, not the same a testing the components. Is you ABS light on? Any other symptoms?
