Hi,
I have a 2002 Acura MDX. I noticed that the right side low headlight was not working. I changed the bulb and checked the fuse, but it’s still not working. The high beams work on both sides as well as the left low works fine. Can you please advise. Thanks
The trouble could be with the socket contacts for the bulb. Use a test light probe to see if you are getting power to the socket. I would guess the relay is ok since the high beam is working on that side.
