Fuel pump problem
If I want to remove the gas tank on my 96 Dodge 2500 van, how do I find and disconnect the gas lines
You unbolt the tank straps, and then lower the tank down enough so you access the connections at the top of the tank.
Thanks, I hoped the lines were long enough to let it down. However, my wife says I had better let a pro do the job.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280077697
Check this out, and figure out if this something you’re willing to take on.
Thanks again, I think I’ll let a pro do it.
