Will an 89 Ranger wheel fit a 93 RangerA?
should just be 93 Ranger.
Bolt circle is the same but also measure the center hole to see. Test fit first, it should work.
Yes, They will fit fine
I’m not sure about it. I tried to put 92 wheels on a 99 and they didn’t fit. If I recall correctly my talk with the scrap yard guy 93 and up have a larger center hole. It was the problem I encountered.
