How are these lamps removed do they just unplug or will the ring need to be removed first and then the entire lamp comes out?
On the passenger what needs to come out just to get close
Are You Replacing Just The Bulbs? Have You Checked Your Owner’s Manual Or Is That Missing?
There is usually a retainging ring that locks the bulbs in and then a tab locks the wire plug to the bulb. Often headlight capsules need to come out or things moved from behind in order to gain access.
Grease and fingerprints should not get on the new bulbs or they may burn out quickly.
CSA
Thanks
